End of the road now?
But they have been LAN wired connected. It is no different! So no. That is not the issue! I feel you are now trying to make excuses? Every other B&O speaker sold also has a LAN connection. It is never required over a wireless connection! ALL my other wireless connected appliences work 100% with no failures whatsoever. Yet all I get is your connection is at fault" over these speakers? NO! That is not acceptable. And here is another one... App update done today and many, not all, sound settings reset to zero again! Everytime! Just a horrible piece of equipment to live with!
No excuses at all, but these "wireless" speakers can be interpreted two ways. My way (wireless PL) works flawless, your's (wireless sources) not. I can't speak about your equipment (partial) because I do have most others. But my equipment is nor horrible, it is in general terrific.
  1. did you set or ever tried to set static IP addresses for Core and/or BL50?
  2. Beosystem 7000 is connected and works flawless
  3. Beoconnect Core is USB connected and works fine (in response to my post)
  4. the Halo seems to work fine also (but it works through IP not bluetooth)
  5. Do you have a Beoconnect or Beosound Core? or both (one time you name it Beosound the other time Beoconnect)
  6. There is a flaw in Mozart devices: if I try to stream DNLA music to BL8 and/or BL28 often the sources do not start. maybe the same type of problem as you have?? But I use a work around (easy with an exess of equipment).
  7. I do have several BR1 BT, none of them hardly did ever lose its connection. Is the BR1 close enough? Is the BR1 not been set to connect to another device (easy to have and most pleople do not notice and most people didn't notice that the did set it this way)?
  8. The B&o app: the BL50 part can be flawed or not, but I simply can't know and say anything about it. But it seems the origin for most of your ploblems. For my setup it works fine (again).
What I do not understand in your use: why use bluetooth to stream music to quality speakers.
They are sold at 50,000 GBP as "wireless" speakers. To try to argue that that has conditions is really pathetic!
I had a Core. That worked flawlessly, Now replaced with a connect core. Nothing but connection issues!
You ask why Bluetooth? That is the way the connect core is designed to receive music? How else? Or am I missing something?
They are sold at 50,000 GBP as wireless" speakers. To try to argue that that has conditions is really pathetic! I had a Core. That worked flawlessly, Now replaced with a connect core. Nothing but connection issues! You ask why Bluetooth? That is the way the connect core is designed to receive music? How else? Or am I missing something?
Again, I'm not ridiculing your arguments, I only give other arguments, my arguments. I do not have your experiences and my equipment (a lot) does as expected and does it extremely well. I'm not going to argue about bluetooth and sound quality, find out for yourself. Furtheron it is not the only way to stream. There are better ways.   Hopefully you'll find a way to get everything working the way it should and can, succes!
Hmmmmm....
Well today I suscribed to Spotify instead of Apple music.
I have just spent 30 mins listening to their way (however that is?) of connecting to the Beoconnect Core and I am so unimpressed I will now cancel my sub to them! Incredibly weak and thin lacking in detail and depth!
It is so woefully down on sound quality compared to bluetooth connected Apple music.
So whilst you critise my choice of bluetooth connection perhaps you could enlighten me as to what is better?
For sure Spotify has failed misserably!
Qobuz (.....I prefer it combined with Audirvana)
Tidal (can be accessed by/ is integrated in the B&o app)
Standard Bluetooth does not have the bandwidth to support the amount of data that's needed to transmit lossless music.
Instead, it will downsample the signal into a lossy one en route to your speakers or headphones—which is annoying if you're paying a streaming service extra for the privilege of better quality music.
The APT-X codecs does support higher bandwith.
However, the BCC does not support APT-X.
Spotify Connect works differently than transmitting sound via Bluetooth.
The ‘source device’  (typically an iPhone/iPad with the Spotify app installed) is just a controller - the stream is fetched directly from the playing device via the network.
Spotify Connect makes lossless streaming (in ‘CD-quality’) possible - however, only with devices, that have support for it (the BCC does!)
The support for lossless quality streaming must be configured in the Spotify app - and you need a paid version of Spotify for this.
Very few people - that I have come across - would rate the quality of a music stream submitted via BT higher than the lossless variant of Spotify.
Apple Music Behavior: When casting Apple Music via AirPlay 2, the stream is typically re-encoded to 256 kbps AAC (lossy), even if lossless settings are turned on in your app.
You can stream higher quality via AirPlay, but only if your sending device and the receiving device are regular AirPlay/AirPlay 1 devices.
The BCC is an AirPlay 2 device - which limits the quality of a stream that might be available in the Music app in a higher quality.
Yeah well... I was anticipating someone coming out with all the numbers to say this is better than that? So you didn't disapoint.
But I am not wearing it! Spotify on Lossless does not come close at all with Apple Hi res music lossless.
Sorry. Apple wins hands down with these speakers. Living with Spotify woud drive me crazy. It already is!
But is there another way to send Apple Music to the Beoconnect Core as the BT seems to be the issue?
I just managed to swap spotify connect for spotify bluetooth! The difference is sound quality is remarkable. So anyone taking the P out of Bluetooth take a long hard look in the mirror? You are so wrong!
the End
I can do a playful Trump-style parody without presenting it as an actual Trump quote.
My fellow music lovers,
Let me tell you something about Bluetooth.
Bluetooth is fantastic. It is probably the best way—maybe the best way ever—to get music from your phone to a speaker.
You take your phone. You press Bluetooth. You see the speaker. You connect.
Boom. Music.
No cables. No wires. No complicated equipment. No guy coming into your house saying, “Actually, you need a DAC.”
Nobody needs a DAC!
And people say, “But what about Wi-Fi streaming?”
Wi-Fi? Very complicated.
You have to find the network. Enter the password. Maybe the speaker disappears. Maybe it says, “Connecting…” for three minutes.
Bluetooth?
It just works.
You walk into the room with your phone and the music comes with you. You walk outside? The music comes with you. You go to the kitchen?
The music follows.
That's leadership.
And let's talk about range. People say Bluetooth doesn't go very far.
Wrong.
You don't need to send music to the moon. You need to send it from your phone to your speaker.
That's the distance that matters.
And the sound quality? Very good. Tremendous sound quality. Is it the absolute highest possible quality known to mankind?
Maybe not.
But here's the thing: most people aren't sitting in a laboratory with their ears measuring frequencies.
They're having a beer. They're cooking dinner. They're sitting on the sofa.
And they want music.
Bluetooth gives them music.
Instantly.
No apps. No accounts. No cloud. No subscriptions. No complicated nonsense.
Just:
Phone. Bluetooth. Speaker. Music.
Three things.
Very simple.
Very powerful.
Some people will tell you they need a wired connection because it's “bit-perfect.”
Bit-perfect?
Folks, I don't know what that means.
But I know what sounds good.
And Bluetooth sounds good.
It's wireless. It's easy. It's reliable. It's beautiful.
And frankly, if your speaker doesn't support Bluetooth?
That's a very sad speaker.
We need to make Bluetooth great again.
Thank you for your attention on this matter. God bless Bluetooth. And God bless the music.
