Hi Beofile,
As you do, I thing that your problems are connectivity issues.
I also noticed my BL50s sometimes hang when changing the settings.
Not on current use, but only when I confirm settings modifications (inputs or listening position) in the "configure"pages.
But a few moments later it comes back to normal, as if the memorization of changes needed time to proceed.
On current use through the B&O App they are fully responsive.
I also noticed that wifi is a bit tricky with Beolabs, so I connected them through Ethernet, configured them with fixed IPs in the router and have no connectivity issues.
My Beosound (not Beoconnect) Core is also hard-wired with fixed IP and works flawless. So is my Theatre.
As a general rule, I give fixed IPs to all my devices and use Ethernet as a priority.
I do not use bluetooth and have limited knowledge in this technology.
I understand that you use your BR1 with both Beoconnect core and M5.
In my Beosound Core, the Bluetooth settings page have "pair", "always opened" and "settings" items.
- If "always opened" is checked, the "pair" item is greyed.
- Unchecked, the "pair" items can be selected and you can add devices manually.
- And you can choose in the "settings" item if you want automatic, manual, or disabled connexion with paired devices.
As a test, may I suggest that you pair manually a phone or tablet to be used for streaming for each device and see if the problem that you encounter still occur.
Hope it can help,
Yann.
