Eclipse V 2?
Millemissen wrote:
Here is one example from DK:
https://beoaarhus.dk/products/beovision-eclipse-spar-13-700
But it seems, that not all dealers have begun discounting.
Probably will be more common in the fall.
Thanks MM! That is a good discount indeed. Hope this also applies for shops in NL soon
Sooner or later - depending on how many left.....and the official announcement of a version 2.
So it looks like that NL soundbars are not coming anytime soon🙁 what a pity
If it’s selling that well, then why not just keep updating the panels. Spend the available time etc on new products.
Chris Townsend wrote:
If it’s selling that well...
Selling 'that well' in B&O terms or LG terms? ie. B&O probably signed a minimum quantity with LG where they committed to a certain number of parts (panels) to obtain a certain buy price. It takes time to reach that supply point, which is why they can't just 'keep updating the panels'.
I would have expected this eventually.
b&o stock of C7 (custom) panels has finally run out and they need to get another run of the current panels made today - C9. Any consumer television manufacturer makes a run of a certain series, once that is superseded by its replacement, the old model is simply not made anymore and whichever are still floating about unsold, will eventually be.
LG will not make a small run of a discontinued model, does not make sense.
Same will apply to Eclipse V2 C9 panels, those eventually will run out and either the ecplise is abandoned or b&o must buy whatever is current then and hopefully mechanically fits, C12??
Why not?
Will the c9 fit on the eclipse sound centre it does it also require a special version ?
Is it the connector that’s special ?
That is the ‘problem’ - the LG-C7 was costummade for B&O because of the back part.
And a new C9-version must be as well.
That makes it much more expensive for B&O, than just to use a stock version of the tv....and risky too, because they don’t know how many the can sell.
wouldn't you think if they made a V2 that they would work around that? The C9 is mostly flat on bottom so if they basically have the soundcenter top have a flat mounting surface then it wouldn't matter much any more and also they may need a bit more play in the mounting brackets, but that's about it. The dsse board would have to be updated to to work with the app, but other than that it can stay mostly the same if not nearly identical.
