Eclipse USB HDD suggestions
Hi all,
When we upgraded from a BV11 to the Eclipse at the start of the year we decided to drop our Sky subscription and move over to using the Apple TV (integrated neatly into the back), along with NowTV and using Freeview via the satellite dish. This has been working well but having dropped Sky we’ve started to miss the ability to pause live TV, etc.
Has anyone used a USB HDD integrated into the back of the Eclipse for pausing/recording live TV that they can recommend? Checking the online (LG) guide on the B&O website doesn’t give much info other than it should be an HDD with at least 80Gb of storage. We’re aiming to have one small enough to fit into the TV connection panel so it’s hidden away...
Any experience or suggestions would be appreciated,
Many thanks,
Matt
Matt wrote:
Hi all,
Many thanks,
Matt
We have made the same upgrade as you, and after much searching on the internet I have found this ssd / usb disk:
It fits into the usb 3.0 slot next to the PCMCIA card slot, and it is small enough to fit under the cover plate, if you use the supplied cable.
We are receiving tv from a danish cable tv provider (youSee), and pausing live tv and recording works perfectly via the built-in dual tuner in the Eclipse 😁.
Please observe that you are not able to pause or record input from the HDMI connections. It only works with the tuner.
Best regards
Dyssegaard
Hi Dyssegaard,
Thank you so much for the reply, that’s just what I was looking for. I’ve ordered one tonight, and will post an update once I have it installed.
Out of curiosity, did you have to format the drive before use?
Many thanks,
Matt
Hi Dyssegaard,
Many thanks,
Matt
Hi Dyssegaard,
Many thanks,
Matt
Hi Dyssegaard,
Many thanks,
Matt
Hi Dyssegaard,
Many thanks,
Matt
Hi Dyssegaard,
Many thanks,
Matt
Matt wrote:
Hi Dyssegaard,
Thank you so much for the reply, that’s just what I was looking for. I’ve ordered one tonight, and will post an update once I have it installed. Out of curiosity, did you have to format the drive before use?
Many thanks,
Matt
Hi Matt,
You’re welcome 😁, and yes - I did format the drive before mounting it in the Eclipse.
I have a Mac, so I could only format as fat32. If you have a windows computer, you can also use ntfs. However, fat32 works fine. I have a feeling, that the tv itself reformats the drive from fat32 to ntfs, because I have several recordings larger than the 4GB limitation of fat32.
Best regards
Dyssegaard
Hi Dyssegaard,
Appreciate the quick reply! The drive is arriving this evening, so will format it to NTFS and give it a go.
Many thanks,
Matt
