Can I ask if there is a cutout on the sound centre to fit the GX, or the GX simply sit on top?
Eclipse Mk2
Look at the photos in this past week's BeoTalk podcast. The corner shot shows a rear panel cut-around in the top surface of the sound centre. Also the discussion of the prism necessary to route the ambient light down into the LG's sensor implies that is below the top edge of the front panel. Not as dispositive as seeing it in the flesh at a dealer, but pretty likely indicators.
I have hoped for the otherwise but thank you. π
To be fair, just had a price for moving my GX to the Eclipse v2 stand/sound center was actually far more decent than I feared. ie. very realistic option.
I think this will be my plan soon - move the GX 55" to a Eclipse v2 stand and the GX 65" kept on the wall.
How much? I thought our guesstimate is about GBP7000?
That's between me and my dealer :)
Point is, it's something worth considering.
I am happy for you and me ππ
Iβm also curious about how this looks and more importantly if it even works as it should. A stock tv probably donβt take into consideration the change of light levels that it will mean to guide the light and potential loss of light.Look at the photos in this past week's BeoTalk podcast. The corner shot shows a rear panel cut-around in the top surface of the sound centre. Also the discussion of the prism necessary to route the ambient light down into the LG's sensor implies that is below the top edge of the front panel. Not as dispositive as seeing it in the flesh at a dealer, but pretty likely indicators.
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
