Eclipse Alternative
Mikipedia wrote:
And how would one connect beolabs to the loewe tv?
Hi Mikipedia,
For stereo sound, you can connect two Beolab speakers directly to the Loewe headphone socket (as per any non-B&O TV).
For surround sound, the Loewe TVs have a surround sound decoder fitted with a digital output, marked as "DAL" (Digital Audio Link).  First, you need a DAL to Audiolink adapter and an Audiolink Breakout cable from your Loewe dealer.  I can then provide cabling to connect any combination of Beolab speakers (up to 5.1 channels) to these Loewe adapters.
In the case of this enquiry with Beolab 5, 3, 2 and 7.2 speakers, the following cables would be used (please note that the Loewe TVs can only drive the Beolab 7-2 in mono when used with external front and rear speakers):-
Front Beolab 5 speakers: link
Rear Beolab 3 speakers: link
Beolab 2 subwoofer: link
Beolab 7-2 centre speaker (mono): link
Please note that the Beolab 5 speakers will require a B&O remote to activate them before use and a Sync cable should be connected between them to keep the speaker volume levels matched:
Thanks Steve, that is really useful information.
Do you know anything about the Almando Multiplay Surround Decoder?
I really like the Loewe but at £9000 for the 65inch plus the hassle to make it work I feel like I might as well buy the Eclipse
jvdl wrote:
Only a hughe price difference between the BS4 and Almando Multiplay Decoder.......
+@CarolPa
+@BeoBang
But you get all this B&O good stuff for the extra dollars ... although the mythical BeoSystem 5 would be even better:
7.1
Speaker Groups
PUC control
Projector controls
Etc
BeoSystem 5 would be the complete answer as it would be 4K and I would be happy to pay more. Word is that B&O are set to close their television development department in Struer so I can't see the BeoSystem 5 becoming a reality. If anyone knows otherwise please speak up.
End of the month I'm going to order the Almando Multiplay Decoder. After all challenges with my Moment I want to be in control over what music streamer or television I use in the future. I think the decoder will give me the flexibility I need and I'm happy with 5.1 setup only.
According to the Almando site its doesn't have to be 5.1 all the time.
Stereo sources and a surround loudspeaker system
If your TV is active and a broadcast with surround sound is playing, then everything will play in the 5.1 mode - on the two front speakers, the two rear speakers, the center as well as the subwoofer.
If you listen to a stereo source (such as the B & O audio system or your Sonos Connect), the multiplay surround will also produce a room-filling sound - the music will automatically be played back on all 4 surround speakers including the subwoofer in SPEAKER 4 mode
The Bild 5 on a table stand with speaker.
I guess i misunderstood that part then. Sounds better then i thought. What are you planning to use as a center speaker?
I almost certain on getting bl50's, iam just wondering to myself if wtih that kind of power up front if i still need rears. I have a feeling that for films you would miss rears.
Iam also wondering how that almando surround box would route the sound when there is not a dedicated subwoofer in the system.
Anywho i feel this could be a very interesting thread
I hope the thread finds someone who has one or has installed one.
BL50's up front will be great but I'm sure you would be better off with some rears even if they are something really compact like BL4000's or BL3's. I have a BL7.2 I could use as a centre speaker but will probably buy a BL10.
I currently have bl18's as rears and i love them, i think i would realy prefer to keep them.
Bl7-2 and bl10 are both terrific imo, they can both look superb as centers too. Good choice :)
I too hope that somebody with some experience can enlighten us on how well it all functions
