Dyssegaard
Hi, I will try tonight to update my Eclipse 1 st gen.
Please report if you experience any sw-bugs with the new software.
Best Regards
Hi there
My software shows as 2.7.37196.117795280
How do you have 3.2.4........
Maybe to be ready to use the Level tooThis morning new sw was available for my Eclipse here in Copenhagen
Hi,I did a manual search for updates on my Eclipse, and the new version was available. Sometimes they make a staged update, and as I live in Copenhagen/Denmark updates can be available here before other countries. Have patience and Iām sure that you will get the update too šHi there My software shows as 2.7.37196.117795280 How do you have 3.2.4........ Eclipse 65 V1-32 Beosound M5 Essence MK2 BLI
Same here (Belgium), the 2.7.37196.117795280 version, I can't remember when that was released but it must be some time ago.
Maybe we need to change the location to Denmark to get the update? š
Most probably the 3.x update is for 2nd gen
Just got the sw 3.2.42684 for my 1st gen Eclipse installed, not sure yet what the improvements are.
other than a stand update message popping up, release notes are as usual next to nothing
Register to access the forums, reference material, and exclusive member benefits ā including our monthly prize draw.
