Eclipse 1st gen - sw 3.2.42684 available
This morning new sw was available for my Eclipse here in Copenhagen.
I have installed it, and so far I have observed the following changes:
- Stand By light now works as it should šŸ™‚
- DLNA shuffle and repeat functions are OK šŸ™‚
- Chromecast sw updated to 1.44.21
9548 šŸ™‚
Best regards
Dyssegaard
Hi, I will try tonight to update my Eclipse 1 st gen.
Please report if you experience any sw-bugs with the new software.
Best Regards
Hi there
My software shows as 2.7.37196.117795280
How do you have 3.2.4........
Maybe to be ready to use the Level too
Seanie_230 wrote:
Hi there
Eclipse 65 V1-32 Beosound M5 Essence MK2 BLI
I did a manual search for updates on my Eclipse, and the new version was available.
Sometimes they make a staged update, and as I live in Copenhagen/Denmark updates can be available here before other countries.
Have patience and I’m sure that you will get the update too šŸ™‚
Best regards
Dyssegaard
Same here (Belgium), the 2.7.37196.117795280 version, I can't remember when that was released but it must be some time ago.
Maybe we need to change the location to Denmark to get the update? šŸ™‚
Most probably the 3.x update is for 2nd gen
Just got the sw 3.2.42684 for my 1st gen Eclipse installed, not sure yet what the improvements are.
other than a stand update message popping up, release notes are as usual next to nothing
Maybe a Chromecast upgrade to fix the global issue that started weeks ago
