Easy creation of MP3 cd's from BeoPlayer
I have converted almost al my music cd's to wma files for using in the BeoPlayer and BeoMedia. I'm searching now for a easy way to create MP3 cd's (because my carstereo doesn't support wma) directly from the BeoPlayer (using drag/drop). Does anybody have any good experience with any cd burning program or conversion tool? Any tips or advices are welcome.
Regards, Lou
You could do it with iTunes. On a PC, iTunes will convert WMAs to whatever format you want, albeit AAC, MP3, Apple Lossless, WAV or AIFF. I'd personally choose high-bitrate MP3 so you get the least sound lost.
You simply drag & drop the files into iTunes, and it will convert them for you. Beware this will take up a lot of file space. Then drag the songs you want to turn into an MP3 disk into the left hand bar in iTunes to create a playlist, and in iTunes preferences (Edit > Preferences > Advanced > Burning), choose 'MP3 CD'.
Click OK, and then when in the playlist to burn to a disc, choose 'Burn Disk' in the bottom right of iTunes.
Thanks Alex for your resonse. But I'm really looking for a more easy way, direct from BeoPlayer playlists burning a cd in mp3 format. Also having both iTunes and BeoPlayer on a pc your facing lot's of disadvantages.
