early MX7000 +beo4 - setting the clock
Hey, I have an early version of Beovision MX7000, the version that was made to be operated with a Beolink 1000. However, I have a Beo4 remote, don't know if it matters. Anyways, I don't know how to set the clock on the TV. The setup menu is really limited, no clock setting in sight. Can anyone help me out?
/Filip
Hi Filip
Try this
1. Select a TV program which transmits teletext time
2. press <PLAY> then <TEXT>  then the text time is shown
3. press <STORE> <STORE> to save
On BEO4 you need to add the STORE button to list, if you don't know how post it here
regards
Press [Play] twice to display the time on the screen.
Key in the time (24-hour clock) on the keypad.
Press [Store] twice…
I seem to recall that TV was initially designed to work with either the BeoLink 1000 or 5000 remotes. Hope this helps.
Thanks guys!
/Filip
