Dear Beoworlders,
For about 10 years I own a Beocenter 9500. Always loved it and it looks beautiful next to my Beolink 7000. Unfortunately the Beocenter 9500 has some issues at the moment and I'm affraid that it's time to say goodbye...
The first issue started last year. The glass was coming loose. I don't know if it's easy to glue it on again?
The second issue is much worser... the cd and tape mechanism... One of the wires of the intern system came loose while I was cleaning the Beocenter (I heart the sound of a spring when I put a little pressure on the top of the beocenter). After this accident the tape mechanism didn't work anymore.
I grapped some tools and opened the Beocenter. The wires from the tape mechanism were not on the pulleys anymore and I noticed a difference between the springs from the left side and the right side (cd player). I tried to fix it, but it was very hard and on a sudden moment also the mechanism from the cd player came loose... This was for me the "I'm screwed" moment.
I asked my dealer and he told me that it is a painstaking job and because of this it could take hours to repair this problem ($$$). I was wondering if somebody knows if it's easy to repair it yourself, because otherwise I'm affraid that the repair costs will be more expensive then a new (2nd hand) Beocenter?
