DVD1 KeyMaster Operating Instructions
I picked up  DVD1 MKI with a KeyMaster circuit board and installation instructions taped to the inside of the cabinet.  I had the KeyMaster installed and this should make the unit region free.
It is working as using the boot-up while pressing << & >> I have been able to change the region over 20, clearly it prevents the region change counter from increasing.
I think there maybe ways of using the BEO4 or setting it so I dont have to keep changing between region 1 and 2.
If anyone has the operating instructions for the KeyMaster on the DVD1, please advise.
Many thanks, Darren
Hi
Go to the Access Control MENU in DVD 1. Change the Code to 0000, If you will change the Codes manually use the ones below. Auto: 0000, Region 1: 0001, Region 2: 0002, Region 3: 0003, Region 4: 0004, Region 5: 0005,Region 6: 0006, Normally Auto will work on all Dvd's Regions
Brgds/Fritz
Fritz,
Many thanks.  I set the player back to region 2, entered the 0000 access code and I have a region free player, with no more resets required.
Once again  - thank you.
