DVD1 freezing
did you buy it abroad different region if so that might help! seen that written in( av forum)
DVD1 must be powered off (mains lead out), with no disk, and connected to a TV.
Hold down the << and >> keys and restore power. Release the keys.
The display will show "r02" or similar, indicating the current region setting for the player. Use the << or >> key to change the 02 to the region you want. Then press the play button. After a few seconds the TV screen will go blue and this shows that your DVD1 is now re-coded.
However: There appears to be no "multi-region" setting, although the first time I tried to modify my DVD1 the display showed "r--" but after that I could never get back to it! Maybe if I'd been smart enough to hit play straight away it may have made my DVD1 multi-region. Who knows?
Also, I believe that one can only change the region setting for the DVD1 twenty times before it does something nasty, like stick [permanently on the last region setting you chose.
Hello,
According to the documentation here, "There is a limit of FOUR changes to the product over its lifetime (without professional servicing.)".
By the way... Happy new year !
Marc
A region coding issue would not cause a crash, the DVD player would simply refuse to play it.
I've played a DVD-R disc in a later DVD1 before, have you had any problems with any other discs at all?
Agree with Alex, this is not a region coding problem.
Sounds like a problem with the reflectivity of different media. I have used DVD-R on DVD1's with no problem but only after cleaning the laser lens.
In fact I have made a number of DVD1's rise from the dead by performing this relatively simple task!
I agree that your problem has nothing to do with Region coding.
However, depending if your DVD1 is a Mark I or Mark II version, you may need a software update. Years ago I had this type of issue and after the firmware had been updated in the unit, it resolved the problem.
What is the 4 digit Type number on the back of the unit ?
The type number is 4620 (made in 2003) and serial number 17002189. I have another DVD1 (similar age) which does the same. It will play for a while then start to freeze with horizontal lines and the sound will break up followed by a crash. Is this firmware upgrade a free service from a B&O dealer?
I deliberatly went for models after serial number 16255681 as discussed in
