Hi all I have just added a dvd 1 to my surround set up consisting of bv5,lab 1,6000 and lab 2 the problem is I cant get the menu toolbar up to change the sound setting to digital.the manual online says hold blue button but the camera angle only comes up.If I press go 3 the other menu comes up.It is totally doing my head in apart from that the dvd player works fine but I cant get digital without getting the toolbar up,please please help.
dvd 1 help
Hi try the green button with a disk in and the scroll through the menues. You might also try to get into the menu with no disk in the machine.
I have the same 'problem'. The manual describes the method necessary to access comprehensive audio and other menu options, but I only see 'camera angle' and nothing more. If I remember correctly, when I asked on this forum some time back why this is the case, the reason given was something to do with the model of DVD 1. Apparently early models didn't/don't have this facility.
Of course I may be remembering incorrectly and totally wrong, but whatever the reason(s), I can't get the majority of the options shown in the manual and so it seems 'Butch', neither can you!
Bit of a 'bummer' I think bearing in mind the price of this unit when introduced. Fewer options and facilities than a supermarket own brand!
Dear Mr Tue,
I think it would be decent of Bang&Olufsen to send me a cheque for £750 as you really ripped me off with the DVD1 what a fat box of junk!
Thanks for the advice but I have tried every button and still cant access it,every other menu but the toolbar,I need to to change the digital coax to ALL to get dolby digital etc
Dear Mr Tue,
Hi Paul, totally agree. Let me know how your claim goes and more importantly, when your cheque arrives!
