Does B&O support DVB-T2 for Beovision 8-40? (Yes I know that the DVB-T standard is supported)
DVB-T2 support
But B & O are working on a new module with support for T2. !
Can you please tell me what T2 is? What is the Difference to DVB-T?
sorry, article is in German ...
Sweden does also use DVB-T2 for HD channels. B&O confirms that they are working on a solution, but they cannot give a release date.
Ditto for Finland. New multiplexes will use DVB-T2 and MPEG4 for both SD and HD channels on them. Currently the only TVs with integrated DVB-T2 receivers are from Sony. Plenty of people who think they just bought a state of the art TV will be disappointed when the terrestrial HD broadcasts begin, and they'll be getting an STB again if they want to receive them...
In a nutshell, DVB-T2 differs from DVB-T by using improved modulation techniques. For the same frequency constraints (channel usage), this can be used for either much improved bandwith or more robust transmission. Delivering HD channels over plain DVB-T is quite wasteful. The robustness comes in handy in sparsely populated countries like Finland, where getting proper area coverage quickly gets expensive.
Today Bang & Olufsen has sent a mail to me to tell that DVB-T2 now is supported with the new DVB-HD Mk III module. 🙂
Problem: Channels that er transmitted in DVB-T2 where CI+ is used to copy protect the signal does not work with the software version 0.1.7.2. B&O will probably solve this in a new software version, but no date is available. This is a problem with some of the HD channels here in Sweden.
The signal can not be decoded.
