DVB-S/T Module for BV7
Dear all,
I have the DVB-S module as in the picture and it should fit into BV7-49 MKIII+MKIV. On the Mounting handbook the code 1438300 and 1438400 is statet. Can anyone tell me if this module also fits for BV7-32 MK2/3/4?
It should also be DVB-T but I miss a socket for it. Can you confirm?
Thanks a lot,
Heribert
Hi, it wont fit a MK2 for certain and a combined DVB-T&S wasnt avaiable if I can remember for the BV7-32, it also looks like your missing a cable for the T connection.
Regards Douglas
Hi Douglas,
not sure I fully understand.
Do you think it works as DVB-S for a BV7-32 MK3 upwards?
Heribert
Hi Heribert,
DVB modules for BV7-32 MK1,2&3 are diffrent from modules for BV7-40, DVB Modules for BV7-40 MK1&2 are diffrent from Modules for BV7-40 MK3,4&5.
You can allways check what modules were/are avaiable still for older products on the Bang&Olufsen Product Archive site!(Google It) with their respective model numbers.
For e.g a BV7-40 MK2 had its own DVB-S or DVB-T module but can now be upgraded to take the newest DVB-HD module.
Regards Douglas
p.s I hope this is a bit clearer
4384 Module work ONLY whit 7-40 MKIII (Type 9370-9384 and 9388), 7-40 MKIV (Type 9439-9455) and 7-40 TV (W/o DVD-BD Type 9456-9471).
