Downsizing from Beoalb 5 to Beolab 20 - Questions regarding Digital connection (Toslink) of Beolab 20
Geoff Martin wrote:
You obviously didn't chew on it enough. ;-)
Cheers
-geoff
Haha true!
Geoff Martin wrote:
js wrote:
Geoff, could you relay these questions within B&O? Please...
Already done. :-)
Many thanks, very much appreciated πŸ™‚
Geoff Martin wrote:
I don't know if there is a big "winner" in the market between the Toslink vs. S/P-DIF Coax. I see both roughly equally on various levels of equipment. [...] Many (but by no means all) devices have a Toslink output. Many (but by no means all) of those are volume controlled. [...] Currently, I believe you are correct in saying that no B&O Player has a Toslink output. I would disagree with you regarding the third-party devices. I have one on my desk right now that has a disable-able volume control that works quite well.
Fair comments and I am happy to have been corrected. I suppose I have not got a broad enough view on the market and I will do more research.
Geoff Martin wrote:
It's interesting to me that this is an issue for the digital input, but not the line input. Perhaps it's because, typically, the gain control of a line-level signal is typically implemented better in a hardware device (like a stereo preamp, for example) than what we would typically see in free software like iTunes. Another good reason why I should dig into the behaviour of the "high end" SW players like the ones listed in your posting.
It is indeed more an issue for the digital input for the reason you mention (and I am happy that you are interested in testing the abovementioned SW players, thanks for this). In my case there is also another reason: I believe analog solutions are still more widespread and straightforward (but again I should probably do more research): I know I can add a monitor attenuator or a stereo pre-amp between a DAC with fixed line and the BL20 analog input. But except for a Mac with a high end SW player, I still don't know what to do between a HiFi player with a digital output without volume control and the BL20 Toslink input.
All in all I agree with you that there are always solutions both for analog and digital. Bottom line the only thing that I mean here is that a Beolab with integrated volume control is a much more elegant and convenient solution (in other words: a more B&O solution). This would facilitate the integration of Beolab speakers into a wider variety of setups (which some reviews also mentioned is currently cumbersome except for BL5). For customers like me this (or a B&O pre-amp) would add very much value to the new Beolab speakers and this would potentially result in higher sales for B&O.
Again, many thanks for having taken the time to listen and for having provided extensive replies in this thread. πŸ™‚
Sebastian
Same here. I really hoped that I could connect an Auralic Aries with Beolab 20 through Toslink without having to use an extra DAC (with an extra control, and so on..). I assumed the sound to be wonderful, coming from Tidal for example. Unfortunately, it does not appear to be that easy.
Hi Geoff and forum
I have a pair of BeoLab 18s connected in daisy chain fashion to an Autonomics Mirage MMS2A media server and they do sound brilliant.
However every 3 days like clockwork they start making a crackling noise then I reboot the speakers and all is fine again for another 3 days. It is not the cabling or autonomics for sure must be a software thing as the tosh link always remains active.
Any clues, because the lab 20s if their software is similar, may behave in a similar fashion when connected in this way?
Thanks for reactivating this thread.
These questions now come up again, when 'the new big' speaker is mentioned.
Of course people - used to the digital connection of the BL5 - want to know if the connections can be done the same with an improved new speaker.
Which connections this coming speaker will feature, is still unknown - surely there will be PL (analog) WiSA (digital). And we don't know, if the 'big one' will have the built-in volumen control like the BL5.
Some people will certainly want to use it without a B&O setup.
So the question remains:
Will there be a (official) recommendation on how to use the digital (S/PDIF) input (supposedly there will be one) with 3rd party hard- or software-players?
I guess this then would be similar for the BL20 and the other new speakers.
I know a little to much how the structure looks like at B&O.
B&O have designed and developed the Wisa 160watt module together with Wisa Association, and Toslink where included in the "bundled package" from Wisa, like a feature that just where included on the patent Wisa module, and now they struggle with what to say are the meaning with the Toslink without volume control.
(Wisa are a association that consist of many different companies including B&O)
It always like this..
B&O buy off the shelf preconfigured components from third part in many cases, and then they decide what to save or what to let go.
Many times they are to conservative and throwing features or inputs in the garbage can to fast, and realise it to late. -Oh we need a AUX input on the BeoSound 5 after four years of thinking, or we implement Spotify after 5 years. And many other things, like converter boxes for everything.
Or BeoSound 6 , DVD2 (Philips) its another case.. You cant just strip out features and take High-End price on a repacked Alu product with poor SW.
Its old costly conservative thinking sadly, and always have a backup answer for all weird solutions. And after a while a Mk II model see the light with the feature that everyone asking for from the beginning.
B&O are not and will newer be Apple , so do not go in to the gladiator arena and try to wrestle with the big boys, do what you are god on doing. The core is picture and sound, in a designed package, not any fancy Software OS that are programmed and outsourced to a company in India.
So step out from the old basement and see the light, and don't come up with some bad transparent answers in the future, itΕ› better for the company reputation!
I understand Geoff, that you are like a top chef at a middle class restaurant with limited budget. In your dreams you wish to only work with premium meet/fish/beverages, but the owner just say; this is what you will have to work with, and do the best you can with it, so no shadow on you.
My tip for the month to B&O board members and development section.
at least a studio quality desktop solution exists from TC Electronic:
BMC-2
Of course, it's impossible to say for sure, but I have experienced some audio errors that you might describe as "crackling" as a result of too much attenuation of the light level on the Toslink cable.
In my case, the problem was some combination of:
  • a cheap Toslink cable (I've learned that low-quality plastic in the fibre optics attenuates the light over distance)
  • a long Toslink cable (see above...)
  • a poorly-made termination (I just cut the end of the cable with a pair of wire cutters and didn't flatten/polish it - my fault)
This caused the Toslink receiver hardware on the BeoLab 18 to get enough light to think it had a signal (so it played something...) - but not enough light to actually get a clean signal.
So, I would say that one possible thing to try to fix your problem would be to swap your toslink cable. If you have the problem on both speakers, then swap the one feeding from the source. If you have the problem on the "downstream" speaker only, then swap the one connecting the two loudspeakers.
Then again, this might not be your problem - but it's the first thing I would check.
Cheers
-geoff
PLEASE READ before sending me a Personal Message.
If you have questions about or problems with B&O equipment, these should be directed through your dealer and/or B&O's Customer Service department.
I cannot be a "short circuit", bypassing these communication channels.
-geoff
I have a pair of bola 20's for sale
They proved too small for my application, is anyone interested?
Where are you located?
