hi guys
how can i tell if my Beosound 4 has DAB? its on a stand so i dont want to dismantle it, and my invoice from B&O gives me no indication. There are about 30 preset radio channels, if that helps......................
Thanks guys
Kevin
hi guys
Thanks guys
Kevin
Hi Kevin
If you PM me your serial number, I can check the type number of yoru unit which will indicate whether or not yor have the DAB tuner fitted.
Regards
Opman
done :-)
