Does Essence remote work with Playmaker?
Hi guys,
I am trying to understand the differences between Essence/Transmitter/Playmaker all day, but I am more and more consused.
Guy offered me (for a very good price):
1)Playmaker (mk1)
and
2)Essence - only the wheel, without a white box (also mk1 I assume).
I would like to connect these to my current Bolab 8000, so I open my macbook air (iphone), start iTunes, play music via airplay to playmaker and then go to kitchen and use Essence there to change volume/pause music/skip tracks. Is it possible?
Thank you.
P.s.: what is a fair price for Beolab 12-3?
Does Essence remote work with Playmaker?'
The answer is quite simple: No!
I think you are wrong MM.
a Beo4 works with playmaker, so a Essence remote in Beo4 mode should also work.
I'm not 100% sure tho
Also, there are listing on ebay, where these 2 things are sold together as they are supposed to be used together..: http://www.ebay.com/itm/Bang-Olufsen-B-O-BeoSound-Essence-Remote-B-O-Playmaker-I-Ships-Wordwide-/161756724307
That is why I am confused..
http://bogo.custhelp.com/app/answers/detail/a_id/10014/~/can-i-use-beosound-essence-remote-with-another-bang-%26-olufsen-product%3F
Thanks, that is interesting, but I did not find playmaker mentioned there..
http://bogo.custhelp.com/app/answers/detail/a_id/7050/~/both-my-audio-system-and-playmaker-react-to-commands-from-beo4-and-beo5%2Fbeo6
That depends on which source the ir command of the 'wheely' can trigger.
'To select an AirPlay or DLNA source, press A.MEM on Beo4.'
I guess it also depends on the version of the 'wheely' - the first ones did not have the additional ir modes, that the later ones have.
He wants to start playing from his source, then only use skip tracks and volume. This will work.
The proof of the pudding is in the eating ;-)
