Does anyone recognize this part?
Leslie,
I have the white M70s you sold me mounted on B&O trumpets and before the M70s the stands had S60s.  In both cases the bolt is used after the speaker is mounted to either fix it or to tilt the speaker.
Richard
Hi Richard,
Did I sold you M70's?😂 I really must be getting old. Can't recall to be honest.
Never had M70's. Anyway, thanks for your reply, Now for sure I know how it works!
Or you sniffed to much solvent from paint and cleaners while restoring your B&O's! 😎
@Richard,
Help! Blackrix is accusing of sniffing to much, please tell them I did not sold you the M70's😎
Blackrix, I confirm that it was not Leslie but somebody called Carel that I brought my white M70s from.  Maybe I discussed another Marktplaats sale with Leslie (AV9000????)
Richard
Ah, so Leslie is not sniffing paint or glue or something else. Well, at least we can't prove it.......😕
The only place where I'm sniffing is Marktplaats or Ebay😁
Nice trumpet stands, Leslie.  My two pairs of M70s are jealous.
Then we should join them don't we?😁
