Thank Geoff for your through explanation.
So the loudness on my BS3 is like a "intelligent" boost. Something I have to try.
Currently I adjusted all my speakers to around 64db and the subwoofer at around 68-70db, I have already dialled the subwoofer level to the lowest and the BL2 is already set to "corner", and that is the lowest db I can get from the subwoofer. To compensate, I have tried to move the BL2 away from the wall as far as possible. Having said that, I am not getting booming so I am happy.
I am still confused with the "Bass" control....I guess I have to try and see the difference for myself.
Thank you very much!
While we are at this topic. Can someone explain a newbie question...
1) Loudness is suppose to bring up base at low volume level. What is the difference between turn on loudness vs bringing the subwoofer up 1 or 2 db higher?
2) What is the difference between adjusting the subwoofer db vs adjusting the bass level?
Thanks!
1a. If we assume that your subwoofer is part of a bass-managed system, which would mean that it's producing the bass from some frequency (typically around 120 Hz or so) and down - and no other loudspeakers in the configuration is working in the low end, then turning up your subwoofer by 1 or 2 dB will increase the level of the frequency range that it covers (let's say, 120 Hz and down) at all settings of the volume control. So, you'll have more bass, no matter what the playback level.
1b. If we assume that your subwoofer is dedicated to only playing the LFE channel from a multichannel signal, then the effect will only be applied to the LFE channel - still at all volume levels.
1 - generally: A modern "loudness" function increases the bass (and, in sometimes the treble) by a different amount depending on the setting of the volume control. The more you turn down the volume, the more the bass and treble are increased in level to compensate for the fact that your hearing system's "frequency response" changes with levels. The quieter the signal, the less able you are to hear low and high frequencies... If you want to hear the same spectral balance of your music regardless of the volume setting, your system will have to do something to compensate for the changes in you.
Also, the typical Loudness function will increase the levels by a lot more than 1 or 2 dB. A current BeoVision television in its factory default setting will push up the bass by 12 dB and the treble by 9 dB - although you can customize these values to suit your tastes.
2. The answer to this depends very much on the specific behaviour of your particular system. However, generally speaking, a "bass" control has a wider bandwidth than a subwoofer, and it will add bass to all audio channels (if you aren't bass managing, this means that you'll get more bass in all speakers...) (Remember: I said GENERALLY SPEAKING - so please don't send me angry messages about a specific subwoofer and a specific bass controller compare to each other. You'll ruin the perfectly nice cup of tea that I'm drinking right now...)
For more information that might help - I wrote an article explaining loudness functions in general on link. This also shows some example response curves from the BeoVision televisions (the current ones have the same behaviour as the ones listed there...)
Cheers
-geoff
