Disassembly frame Beovision 9
In the meantime good morning everyone, I'm a new user. My name is Silvio and I live in Parma.
I love B & O since I was a child. I love their design.
I am a lucky owner of some of their products and I'm happy to be in this forum.
Step to the question ... have you the istruction to remove the frame of the Beovision 9? I would like to change the color of the canvas from black to white.
Thank you all, Silvio
Just pull towards you. Gently.
Mind cable from the camera (if present) and/or earthlead at the bottom.
Last night I tried but nothing. So ... pull towards yourself?
Yes, with your fingernails behind the frame pulling it towards yourself.
You need to dare with apropriate force.
I try this evening. Tomorrow I'll let you know. Meanwhile, thanks
Just start at the left or right top to the other side and then downwards.
Plastic clips are holding the frame.
Done!
I Board of starting from the bottom (left or right is the same) to push with your thumb, on the cloth, because below is rigid.
I have already removed the panel and have already brought at changing the cloth, from black to white.
Thanks to all.
Nice!
Next are the pictures with the white cloth?
Of course! ;)
Welcome to Beoworld 🙂
Did you remove the entire aluminum frame to change the cloth?
I just took off the cloth part. (But to be honest I also broke a clip, that is now laying somewhere inside the cabinet 😮)
