Hi colleagues,
Unfortunately one of the Beolab 4000 switches continuously on and off. Presumably the main board is defect so I have ordered a new one. Can anybody tell me how to open the speaker?
BR
Hi colleagues,
BR
Pull the grill off, then you have to remove the front plate via some small torx screws.
The rest is self-explanatory!
Good luck!
It is done! I bought a new main PCB from B&O and replaced the old one. That solved the annyoing power switching. Only EUR 110,-.
