I found instructions on this forum how to disable the doors on a 3200:
Shift 90369 (list/shift with Beo 4 remote)
I tried this on my 2300, but no result. Doors still opening.
Question: is this possble on an old 2300 (type 2616)? Or is the only option to disconnect the IR sensor completely?
Why would I want to turn off this wonderful feature?
- mechanism is worn, doors aren´t always closing.
- Every time I get near it, the doors open. (Wall-mounted in the kitchen).
- Don´t use the CD. Only radio + Chromecast.
- Everything can be done via the remote.
