h1npw wrote:
That's great - thank you!
The only thing that's making me indecisive is a new non-B&O one will be about the same price and I'll be able to watch 4K material on Netflix & Prime..... decisions, decisions.....
Cheers
Nigel
That will not be possible - the tv is a 1080p setup, although a very good one.
But - as beojeff wrote - the difference to 4K probably will not be an issue, once you sit down and watch a movie/warch tv.
However - as moxxey writes - why go for ‘older’ technology, when you can get a LG screen/Beosound Stage/Beoremote One combo!
As good as it is, I would only go for the BV7, if I wanted to watch Bluray disc (from the buildin player), need the turning function of the stand and need the ML connection to an older B&O soundsystem - and want to upgrade the sound to a complete 5.1/7.1 setup.
And don’t forget, if you want to control external devices (and you will need these for Netflix/Prime), you must be sure that the tv has the PUC-codes for these devices.
Also don’t forget, that the BV7 is a very bulky unit ;-(
Before you decide, please look and listen to B&O LG/Stage solution at a Bang & Olufsen dealer.
