Anybody knows the diffrence betwwen the beolink converter type 1611 and 1614 ?
Is it possible to upgrade the 1614 to 1611 if the diffrence is only software ?
Thanks for feedback.
The Type 1611 is an Europe version and the 1614 is the US version.
There is also a 1612 & 1613 which are the same as above except released a couple of years later
Keith, are you sure? I had a 1614 some time ago to connect my BC2300 to the BV7 (living in Germany with 230V). The 1614 was in fact similar to the 1610 (AV9000 Link Kit) except the software was different.
afaik the 1614 is the predecessor of the 1611.
Marcus
On the 1614, it is specified that voltage should be 230-240V at 50 Hz, so I don't suspect power voltage as the issue. The software is 1.0.
Any suggestions ?
After Marcus said "are you sure ?" I started asking myself a few questions and doing some research and came up with the following conclusions:-
The Beolink Converter Type 1614 is the older version which cannot perform all Masterlink functions and was replaced by the current Type 1611 with the latest software version of 1.4
The software in the Beolink Converter can be updated by the replacement of IC4 which is in a socket as below
Hi Keith,
How do I check if the current jumper settings and make sur that they are configured for 230V ?
Do you think I can order the SW1.4 and do the replacement ?
First, from a mains jumper situation, there is the old version and the newer version.
The newer version does not have jumpers and looks as below:-
If yours looks like this with the grey transformer next to the red socket, then it is 220 volts and NOT changeable.
If yours is the older version, then it has three jumpers as below. The bottom picture is an enlarged part of the top where the jumpers are located.
By changing the jumpers you can set it to 120 or 220 volts
The software can be ordered from your B&O dealer and plugs into the socket shown above.
