DIFFERENCE BETWEEN MK1, MK2 & MK3 BEOSOUND 9000 !!!!!!!!!!!!!!!!!!!!!!!!!!!!
Is there anyone out there that could tell me how i can tell apart a MK1 from a MK2 and MK3 on BEOSOUND 9000 (6 cd) either physically or functionally or maybe year of manufacture - what are the differences ?????????????????????????????
HELPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP.
physicaly only 1 difference between them
there is on/off red button at the bottom of mrk-1
as my knowledge
The MK I model is upgradeable for N-Music
The MK II model is upgradeable also
The MK III has a different CD mechanism and PIN code security. The glass plate has also undergone several updates as the earlier ones tended to come loose.
From the type number printed on the label under the keyboard!
Mk1 is 252*
Mk2 is 256*
Mk3 is 257*
where * depends on the country of use and is 2 for UK models.
as my knowledge
The mark 1 certainley had the red on/off button. At some point in production this was removed. It was re-introduced last year to comply with legislation regarding power consumption, so mark 3's have this button now.
Opman
Not all MK3 have the pincode.
Your keyboard needs to be exchanged.... CAPS, ?, ! and P don't seem to work anymore.
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Search this forum, you Will find the answer.
ROTFL, you make me laugh hard :)
have a look
http://www.beoworld.org/prod_details.asp?pid=954
regards elmar
