Well, I suppose the transformer is good and strong then.
Replace all semiconductors on the board and on the cooling fin.
Check (or replace) all other components, even ceramic caps.
Do a continuity check on all PCB tracks.
If the board has serious dark spots from heat, it may have turned conductive and must be discarded.
When done, but before powering up, do some ohmic and semiconductor measurements
on strategic points to compare with the working channel.
Power up only using a variac with a current limiter and monitor the idle current from the moment power
is applied. If it runs astray pull the plug immediately.
As I told you initially in the first thread, this is not an easy thing to repair, there are no shortcuts.
The easiest and often cheapest method is to find a complete replacement module from
a donor machine, especially if you are not 100% into the soft clipping DC coupled complementary
output stages circuitry in this power range.
A full set of output transistors alone represents quite a cost and it usually doesn't stop there.
I've had some fireworks here too, you know.
