Delay BS5 via ML/NL Konverter to NL Products
Hi, At the moment we own a BS/BM5 with BL6000 which is connected to the Converter. When we distribute music from the BS5 we always have a delay (BS5 is "faster"). My dealer told me that the only way out of this is to switch to a BS E or M.Do you have any Ideas? (The delay time in A9/A6 and NL Con is reduced to 30 wired/ and wireless). Otherwise we will sell our BS5[:\'(]. Thanks!
It's not clear from your description whether the BL6000 speakers are connected to the BM5 or to the NL/ML converter - can you confirm which is the case?
Martin.
Hi Martin,The BL are connected to the BS5. When I connected the BL to the Converter, it was strange to us to use the beosound.Activate BS. Then separate the mainroom speakers. (With no or just a really tiny delay). Thanks for your help.
Hi Martin,Yes, the BS5 is the only ML Product. I'll try your recommendations. My dealer told me ML Role Audio Master, that's probably the reason why it was really strange to use. Thanks again.
Hi Martin,Everything works!Thank you!
Great - that's good to hear.
Enjoy!
Martin.
Hi Martin,Today I tried to use the beoplay app to control the system. Maybe you can give me in this context some advice.Spotify (used with the BM5) or Radio is distributed through the house to netlink speakers. - works fine. (Control via the App is not always working). If I try to distribute Deezer from the A9 to the speakers connected with the converter I recognized two things. 1. I can not add the speakers via the app. (A6 works)2. If I press join on the IR Sensor. It works. Do you have an Idea?(Of course this is not a big issue because we use Spotify and I just tried the test month with Deezer, but I try to understand that. (Or I made a mistake in programming the Converter 👍))Thanks again for your hints.
found my mistake - I have to tell the converter that I'd like to control the converter with speakers not the BM5.
Fulgore
