Default speakers BV11 / BS 9000
Hello All,
I was wondering if anybody knows if its possible to have a standard speaker joined? What I mean is that I have a Beosound 9000 connected through a NL/ML convertor to my BV11-46. Neither the BV or the BS have speakers connected to them so I use the TV speakers. I do however have a Beosound 2 that I now manually join each time I start playing CD's. Is there a way that the Beosound 2 will join by default? This wil save me going into the app and I can just use my Remote One.
Thank for you help!
Thanks Carolpa. Unfortunately my Remote One is without BT.
a follow up question is weather i can assign a default sound profile on the BV11. It now always defaults to Music but i would like it to default to my custom one.  Is it possible?
