Deezer HiFi
I have a moment with BL20s.and Beogram 9000
I purchased a line in cable to connect the iPad direct to the moment.
When I play from the Deezer app it shows HQ in the album artwork, not flac as has been reported elsewhere.
I haven’t seen any change in the B&O app.
I prefer to use the line in for my Beogram.
The line in sensitivity adjustment on the moment seemed to make no difference to the volume setting. Beogram 9000 is fine, iPad connection from the headphone socket is very low.
Has anyone else seen this?
I haven’t heard a massive difference between HQ from Deezer and playing through the B&O app, but with the messing around with connectors, and input sensitivity settings , I have not given it a proper test. However, when I get the opportunity to have a good listen , if I don’t get a difference I will downgrade my Deezer subscription,
Still waiting for firmware 2.2 🎶
B&O fan since 77.
When you have DeezerHiFi then on the iPad or iPhone you will not get FLAC but only the HQ.
As far as I know HiFi is only supported on selected Audio equipment. Luckily B&O is among those since a few days. 🤩
So if you use your iPad as source then you will get HQ not FLAC.
Check out Deezer support page.
https://support.deezer.com/hc/en-gb/articles/115004588345-Deezer-HiFi
Deezer HiFi + ECM Catalogue on Deezer, what else?
Is there an easy way to browse the ECM catalogue on Deezer?
Not that I’m aware of. I have tried to search for ECM and a couple of playlist came up but not very helpful.
I guess we will have to rely on knowledgeable users to build some playlists and it is a suggestion I’ll make to Deezer, i.e. label search capability
I guess you have to pick record by record.
Maybe this
Playing Gigi FLAC on the Essence joined with a BLC nl/ml ... sadly the FLAC does not come through ... if I am to believe the UI
elephant wrote:
Playing HiFi FLAC on the Essence joined with a BLC nl/ml ... sadly the FLAC does not come through ... if I am to believe the UI
BeoNut since '75
I’ve got a Beosound Moment, and there still isn’t an official update to allow Deezer Hifi (flac) to be played.
Does anyone know when this update will be available?
Thanks.
