Hi, in the FAQ, there is mentioned, that unscrew the datalink pins if connecting to a 5 pin DIN socket. Do I need to open the connector, or use pliers to screw them off from outside. I do not have access to the connector just now, so can't check it out.
Another thing, is there some gimmick to connect Beogram 9500 to an Ouverture so, that it can be operated with Beo4? I'm going to use Pro-Ject Phonobox in between as pre-amp.
Pekka
