Has anyone else encountered the challenge that the CX100 woofer speaker grills do not fit in to their recesses correctly?
I have just taken off, cleaned and double sided my white covers back on (only one speaker so far). I could not get the end of the woofer covers closets to the tweeter to pop all the way in. So I took one of the uncovered frames and tried to insert it to see what was going on. Even that frame did not pop all the way in.
Looking closer the section of frame in-between the 2 snap details hits the speaker's metal frame. I loosened the speaker retention screws to see if I had mispositioned the speaker when I put it back in. There was no play. You can get the frame to slide past the speaker by applying pressure in the mid section towards the tweeter. However you can't do that once the cover material is in place! I am thinking this may be a small (dare I say this) design fault.
I am considering taking 1mm, or so, off the frame depth where it interferes. Enough clearance for the snaps to engage, but still have a structural integrity. Am I crazy? Am I missing something?
I'll post pics when I get it done later this week.
Cheers,
Jamian
