English:
(Dutch down below)
At home I have the following devices from B & O.
- BEOMASTER 4500
- BEOGRAM CD 4500
- BEOCORD 4500
- Beovision 10-40
- Beo 4
These devices are currently connected as shown in the diagram “current system” by a person who knows B & O well. This setup works well from the Beovision’s perspective. What I mean by that is, when I select on the Beo 4 that I want sound over 3 speakers. Then this also applies to the 2 BeoLab speakers. If I select a task from the Beomaster on the other hand, then nothing happens, the MUTE button seems to be there for decoration, for example. If I press MUTE on the remote, it works. But the sound is muted by the Beovision.
(Sound control does not go via the Beomaster, input does)
My goal is to adjust the setup so that everything should work as originally intended. I made a plan for this. This is also in the diagram called “new system”. In this setup I thought that everything should work correctly via the Beomaster. I haven't adjusted this yet, this is a huge hassle (cables through the ceiling etc.) and I hope to get opinions and experiences from others first.
I would like to keep the option to watch movies over the 3 speakers, for example. I thought that according to the “new system” this should go through the AUX button on the Beomaster.
Incidentally, it also seemed like a nice idea to purchase a second-hand Beolink 1000 to make good use of all the functions of the Beosystem.
I would like advice on my setup. What do you think? Would you do something else? Do you have any suggestions?
Thanks in advance!
Rolf
Dutch:
(English above)
Beste Lezer,
Thuis heb ik de volgende apparaten van B & O staan.
- BEOMASTER 4500
- BEOGRAM CD 4500
- BEOCORD 4500
- Beovision 10-40
- Beo 4
Deze zijn aan elkaar verbonden door een B & O kenner zoals afgebeeld in het bijgevoegde diagram “current system”. Dit werkt goed, vanuit het perspectief van de Beovision gezien. Wat ik daarmee bedoel, als ik op de afstandsbediening selecteer dat ik geluid over 3 speakers wil. Dan gaat dit direct ook over de 2 Beolab luidsprekers. Als ik een taak vanaf de Beomaster selecteer daarentegen. Dan gebeurd dit niet, de MUTE knop lijkt er bijvoorbeeld voor de sier op te zitten. Als ik op de afstandsbediening op MUTE druk, dan werkt dit wel. Maar wordt het geluid door de Beovision gedempt.
(Geluidscontrole gaat niet via de Beomaster, invoer wel)
Mijn doel is om de setup aan te passen zodat alles zoals origineel bedoeld zou moeten werken. Hiervoor heb ik een plan gemaakt. Deze staat ook in het diagram in de bijlage “new system”. Op deze manier bedacht ik dat alles juist zou moeten werken via de master. Dit heb ik nog niet aangepast, dit is een enorm gedoe (kabels door het plafond enz.) en ik hoop eerst meningen en ervaringen van anderen te ontvangen.
De optie om met 3 speakers bijvoorbeeld films te kijken wil ik graag behouden. Ik had bedacht dat dit volgens het “new systeem” zou moeten gaan via de AUX knop op de master.
Overigens leek het mij ook een leuk idee een 2e hands Beolink 1000 aan te schaffen om alle functies het Beosystem goed te benutten.
Graag zou ik advies willen over mijn setup. Wat denkt u er van? Zou u iets anders doen? Heeft u suggesties?
Alvast bedankt!
Groet,
Rolf
