Zitat: "If I remember right, you will need to remove the Datalink pins (and disable remote control functions) from the DIN plug to do that. Otherwise, the Beomaster will switch to the CD input every time you start the Beogram as it is using Beogram, not Beocord type of datalink commands.
Or, use the CD input if you don't have a CD deck in the system."
Correct! If the Beogram is connected to the Tape (1/2) Inputs and Datalink Pins are not removed from the Begram plug, the BM7000 will Switch always to Phono Inputs when the Beogram is used.
But removing the Pins will also result in not beeing able to control the Beogram by a remote control, just by the beogram itself.
But it is possible to Keep the Beogram plugged in the Phono socket.
1.) The BM7000 has usually no RIAA inside. This is an Option. If it is installed, there is usually no possibility to connect a BG7000... 2xRIAA does not work. So the Option is to remove the RIAA out of the BM7000 and to repair 2 cut wires.
2.) Remove the RIAA out of the BG7000... what a terrible waste of time and Money.
3.) Install a Switch inside the BM7000, activating or deactivating the installed RIAA inside the BM7000. This Option is undocumented... but possible.
There are 2 wire bridges on the preamp board, J21 and J22. These wires are cut, if a RIAA ist installed or closed, when no RIAA is used in the BM7000.
If the optional RIAA inside the BM7000 was installed and you wish to use it without the RIAA, then unsolder the capacitors C1 and C28. This deactivates the Output of the RIAA. If you install 2 small Pins of a chip carrier and a WIMA 1uf foil capacitor then you can switch it on or off just by plug in or out these small caps. On the other hand, you must open or Close the to wire bridges to enable the Inputs without the RIAA... and this can be also done with a pin of a chip carrier and some wire.
Since one pin of the caps and of the wire can always stay connected, nothing gets lost. You just plug in the wire and remove the cap or vice versa. Activate or deactivate the RIAA... and the RIAA stays inside the BM7000.
Easy done in some minutes... but it means, that the BM must be opened and modified.
