I recently bought an avant 28 vcr originating from 1997. When the set is switched on and of there is a crackling sound from the back of the tube. When the TV is switched on the sound lasts for about 4 seconds and when it is switched of it lasts for about 8 seconds. The dealer says that it is not a hazard and that the TV can be used safely as it is. I was offered that a service shop could put some coating (varnish) on the eht which would solve the problem with crackling sound. Is it safe to use the TV as it is now and is the coating trick established?
Regards
Hans
