Correct settings of NL/ML converter for two-ways communication
Hi all,
I hope that you can help me with this issue.
Please look at the photo of my setup. I need help regarding two ways communication. How must I setup the NL/ML converter in order to play NETRADIO stations on my ML TV’s? Change channel etc.
Thank you in advance
Link https://postimg.cc/xcqxn333
what Software is Running on your BS9000?
B&O Multiroom Fan
BS9000 + BS Core + Beosystem 3 + 4x BL8000 + BL2 + BL7-2 // BeoVision 7 32“ Black // BeoVision 7 40“ // Beoplay M5 // BeoPlay M3 // Beoplay S3 // 2x BL3500 // 2x BeoPlay A6 + 2x Essence Remote // 2x BeoSound 8 // BeoVision 10-46 + BL8000 + BL2
Hi jgraefe,
The software on BS9000 is 2.0.
Now, when I press NMUSIC on BeoRemote One in the living room my BV7-55 turns on NETRADIO on the Core via BeoSound 9000. However, on the display "PHONO" appears. Anyway I'm able to fully control the CORE via the IR eye – turn on NRADIO, change radio channel etc.
This is currently not possible on the rest of the ML TV's.
According to this thread you need SW2.2 to use N.RADIO or N.MUSIC on your BS9000:
Thank you very much. I'll try that out!
Also thanks to Guy for linking to a relevant thread regarding this issue.
post sent ............but awaiting moderation..........
That sounds interesting – good tips. Thanks Carolpa.
Actually I already have a NL/ML delay box, but I'm not sure what the delay settings should be set at. All my NL products are hardwired (expect the M3 ofc.)
Do you have any experience in this area?
