Core: was it upgraded?
Was the Core upgraded to support AirPlay 2? Has it been upgraded with any new capabilities or features since it was introduced in 2017?
The Core supports AP2 but this was a software update—not a hardware change.
There was a hardware update made at some point to allow for the use of an IR eye, I believe. That’s the only hardware change implemented so far. If you do a search, you can find a thread or two about that here on the forum with more detailed info. I hope that helps!
Thanks, Curly.  It's good to see that B&O are keeping the device up-to-date, as promised at the product launch/Shape launch.  A good omen for the BL 28 and future smart speakers, perhaps.
I ask the question because I'm expecting some interesting audio announcements from Apple coming at the June developer's conference (WWDC).
Hi, thank you for your answer I was wondering the same question too.
