Has anyone a view on the following problem? I cannot get the bass or treble control to work when using the B&O app on my iPad. (B&O app and iPad ios software latest versions. New Core hard wired to speakers. Streaming music via Bluetooth/Apple airplay to Core). The music from the speakers sounds ok but I cannot tweak it to my particular taste. Any help appreciated. Cheers. Techno.
Core and Beolab 18 problem
If you cannot adjust the bass/treble sound of your lab 18's via SETTINGS through the last updated B&O app software update 3.15.2, try downloading the previous version (3.14.2). The newest version presented me with similar challenges. Until 3.15.2 has all of the bugs fixed, I would stay with 3.14.2. - Hope that this helps.
The 3.15.0 is a beta version (the latest)…for testers.
The 3.14.2 is the regular version from the app store.
Which version of the app please ?I cannot get the bass or treble control to work when using the B&O app on my iPad
If you are a TESTER and have downloaded the 3.15.0 version, try deleting this version. Go to the App Store and download the 3.14.2 version.
I have a better idea…
If you are a tester, you may know that you can roll back to a previous version……which you can find in Testflight.
No need for deleting anything.
But ok!
This previous version happens to be the same that you get when you download the regular from the app store ;-)))
