Controlling Sky+
I have recently upgraded to Sky+ and am not sure of all the controlling functions using the Beo4, can anyone help me? Thanks in advance
anybody?
Your dealer should have given you the card! I'll try and get it for you!
One Sky + instruction card!!
I have the full B&O Tech sheet somewhere. Peter or Lee may have it from the old forum.  If not I'll forward it with some other documents to place in a technical section.
Beoaus
I'm using sky+ with a BV8. Everytime I turn on sky the box auto switches off after approx 30-40 seconds. I normally turn on the tv then press DTV twice on the Beo 4. Am I doing anything wrong????
I had this same issue when I first purchased a Beovision 8 32".  The sky box would turn off after a few minutes of use when using the STB.  B&O eventually sent a dealer to my home who updated my firmware resolving this issue.  My brother had exactly the same problem with his Beovison 8 32" and the same firmware update fixed his problem.
Many Thanks,
Graham
Thanks Graham,
My BS4 needs a software update so I'll get in touch with my dealer and see if they can sort both out.
