Controlling Line out Volume control of MC/MCL problem
Yes I understand that but the ml cable doesn't work on its own. The amp wont do anything with just the ml cable.
I was told that some ml/mcl amps won't work without both cables.
sashaz wrote:
... the ml cable doesn't work on its own.
The amp wont do anything with just the ml cable ...
To find out if your ML/MCL is faulty, try the ML/MCL with a different ML cable
directly between your existing audio system and the ML/MCL.
As a next step connect the ML/MCL directly to a different audio system.
Ha ha i dont have another ml cable nor another bo product. The cable is brand new from sounds heavenly.
