Yes I understand that but the ml cable doesn't work on its own. The amp wont do anything with just the ml cable.
I was told that some ml/mcl amps won't work without both cables.
... the ml cable doesn't work on its own.
The amp wont do anything with just the ml cable ...
To find out if your ML/MCL is faulty, try the ML/MCL with a different ML cable
directly between your existing audio system and the ML/MCL.
As a next step connect the ML/MCL directly to a different audio system.
Ha ha i dont have another ml cable nor another bo product. The cable is brand new from sounds heavenly.
