Hi there,
I have an overture that I have connected to a MCL2P amp via a powerlink cable. The amp works and drives a pair of speakers in the dinning room but the volume on the anthony gallo nucleaus micro speakers is a bit low. I have to turn up the overture to level 30 to get any good volume on the gallo speakers. This then means that the beolab 4000 speakers are quite loud in the living room (also connected to the overture via powerlink). I have used the option to have it as purely a non controlled slave (option 0)
Thus I wanted to know if I can increase the basic level of the MCL2P volume in comparison to the beolab 4000 and then keep this increased volume saved when I use it at any time?
Thanks for any advice.
i have edited this as i have changed the amp to the MC/MCL amp and linked it to my overture with a ML and powerlink cable. I have tried every option and checked the IR sensor wiring and it still does not allow me to change the volume. Inface the ML cable doesnt seem to do anything really as the PL must be connected for the amp to work at all.
