Got another Lintronic TT-238 today to test the ir codes the BV7 sends out to control the gefen switch.
I was very surprised to find out that the BV7 always sends the power off command to the gefen switch regardless if I switch to DTV (HDMI-1) or V.MEM (HDMI-2) as it is configured for the devices on the BV7 with the gefen switch.
What the hell is wrong with that ?
I spend money on the eeprom chips and the software update to have the latest firmware to support gefen switches and what happens, it does not work.
Now I can manually turn on/off devices with Go+0 (Technisat) or Go/manually selecting Hibernation (AppleTV) to use the auto-switch function of the gefen switch to change HDMI inputs. Wow, this can do switches with price tags around 30€, but gefen, as you know, is much more expensive. Sad but true.
