Has anyone had experience with Control4 with the MasterLink Gateway? I see that there are drivers on the B&O website. Do you somehow have to get the drivers installed on the MLGW to see Control4 in the list of devices for programming?
My goal is to control my Philips Hue lighting system via the MLGW. While KNX is appealing, KNX seems to be unheard of in the U.S - even among B&O dealers. Control 4 now has a driver for the Philips Hue.
Ideally, I would like to be able to control my Philips Hue bridge directly from the MLGW. However, I can't seem to find a way to translate the Philips Hue command to the telnet command that MLGW uses for a custom string. My dealer has suggested that I could pay B&O a (rather large) fee to write a custom driver for the Philips Hue. It would seem that a much simpler solution might be if B&O could add a driver to allow HTTP or "curl" control. I'm don't understand computer programming and I'm probably saying this wrong.
Right now, I can turn on my lights by entering the following command via the terminal app on my mac:
curl -H "Accept: application/json" -X PUT --data '{"on":true}'
