Hi, I have a NEEO remote (Control4 bought NEEO) that I use with my A/V system. My A/V system consists of a Sony TV, Beosystem 4 with attached B&O speakers, Oppo 4K BluRay player, ChannelMaster DVR+ (Over-the-Air TV tuner/DVR). A B&O NL/ML converter connected to a BeoSound 4, BL3500 and the Beosystem 4.
The NEEO system can be controlled via a smart phone or its hand held remote.
I have "recipes" that I self programmed into the NEEO done via the phone app and which can be activated either by the NEEO phone app or the hand held remote.
One such recipe is "DVR" where the TV is turned on and correct input is selected. The Beosystem 4 is turned on and correct input is selected. The DVR is turned on such that I can watch live TV or recorded shows via the DVR. I also have some small PC fans that are also started.Thus the system is "brought up" and ready for me to watch TV.
I also a recipe that I named phone which activates the Beosystem 4 and then via the NL/ML converter accepts a separate Bluetooth module connected via line inputs of the NL/ML converter. I then use my phone to play Amazon music thru the Beosystem 4 via my phones Bluetooth.
I can also play my BeoSound 4 via NL/ML and the Beosystem 4.
Yes a NEEO can control a B&O system. One drawback is that the NEEO system consists of a phone app, a remote and a "Brain", where the brain contains the IR blaster (not in the remote). I cannot use my remote to play sound in a separate room only in the room with my Beosystem 4 and Brain are located. Perhaps Control4 has a solution. Beoliving Intelligence has a solution but I don't know about its third party integration.
