Hi all,
As my home will be renovated in 2 months, I am considering changing my audio system.
At the same time I want to move away from surround to stereo, as I rarely watch any content that benefits from surround anymore.
Current equipment:
- LG 55C7 OLED (recently bought this, won't be changing this)
- KEF KHT3005SE surround set and sub
- Onkyo TX-SR607
- PS3
- Sonos Connect using Spotify
- TV Decoder that runs on UTP (so cannot get rid of this and put a smart card in TV unfortunately)
- Logitech Harmony Elite
All sources are connected to the receiver via HDMI, where the receiver acts as a switch and one HDMI runs to the TV. Harmony controls everything.
Speakers considered:
- Beolab 8000 (havent heared this, plenty to be found used for around €1k)
- Beolab 18 (recently listened to this, was impressed, can pick up a demo set at approx €4.7k)
- Beolab 9 (recently listened to a set of 20 [which I presume is better] was not that much impressed with the 20 though this could be the room/positioning, can pick up a used set of 9 for around €3k)
- Beosound Shape (recently listened to a 8 speaker setup, was impressed. 4 speaker set would run around €4k)
I ultimately want to be able to:
- Have a tidy install without any visible cables (would probably wallmount the 18/8000)
- Stream netflix in 4k (tv can do this, but need to get sound out)
- Stream music
- Control everything with one remote/app
I see two routes (though please chime in)
- Keep more or less the same setup, change speakers to B&O, hook up wired to a new 4k-ready receiver, dont change much else (so in terms of control would stay largely the same), or
- Switch to B&O completely, get a Core and hook everything up there. Start using the B&O app, get rid of Sonos, though what about the remote?
I am very much open to any practical advise and/or considerations you might want to share.
Thanks!
