Considering a 2nd life 11-46. What to check?
moxxey wrote:
My BV11-46 gets so little use. It's barely turned on. Will be interesting to look at the number of hours it's been used. Since buying it from my Bath dealer, I doubt it's been on for more than 50 hours in total.
What a waste πŸ™‚
Send it my way 😁
hostler wrote:
Price is fair for a MINT example I'd say - stand & TV combined
Check the fret fabric is unblemished - no snagged fibres - as replacements are getting scarcer and prices rising.
MK4 will have WISA  - check it works OK - if important to you
Check the TV interface - DTT, D-SAT or D-CAB - make sure it's suitable for your broadcast source
Check if it had the HDD option - and if so - check it can record OK
Manually tilt the stand to full left & right extents and listen for gear grinding
The back has a lot of clip-on / clip-off panel to routes cables - just like your 55 - the legs can snap off these if its had a clumsy owner. Not a problem unless the TV positioning afford you a rear view, in which case these panels can then look messy.
Only the ATV3 will fit inside - and even then it's a snug fit - the ATV4 and ATV4K are too big. If you have a lot fo source boxes, then the STB System 7 clamp stand works well.
Oh, and check what model of BEO4 remote you will get - there are various versions.
Listen for audio pops & crackles on startup - I have a 46 and a 55 - both from the secondary market (Thanks LEE!) and both have a mild audible click when the speakers get powered up during boot. For my MK3 46 this has definately 'arrived' since I bought it 3 years ago. The 55 - which is an MK1 - and hence older - already has it. Do you have this on your 55?
Generally, like you, I've found the BV11 platform absolutely rock-solid and an amazing audio master / video master. Picture is stunning, and when fed bluray, gives 4K a run for its money for enjoyable watching.
All things considered, prices are a steal for the 'experience' quality you get - esp. when you look at the price fo a new Eclipse or Harmony!
Hope it works out for you
T
Thank you for the taking the time to compile such an extensive checklist, I really appreciate it.
I was told the 11-46 was installed in July'15, one of the last 11's my dealer has sold. As I got my 55" a few months earlier than that, I expect a BeoRemote one to be supplied with it, otherwise I'll make sure to get one instead of the (more beautiful but less functional) Beo4 which I use with my BV10.
After 4 years of usage, I do not get any crackling noises when powering on the 11-55 speakers, neither the built-in nor the WISA-connected BL18/19's. Hopefully it stays that way.
In the bedroom, the 11-46 will be connected to 2 wired BL6002, so WISA is not needed but it's obviously good to have for the future. BTW, 4 years in I cannot find a way to have WISA and a 5Ghz network in the same room working at the same time. Tried plenty of high-end routers. It simply doesn't work regardless of what B&O and WISA consortium say. In the end I had to enable only 2.4Ghz in the living room otherwise the TV cannot find all 5 speakers.
Both my 10 and 11 are on the easel stand. I have to admit that after so many years (7 for the BV10) the tilted effect starts to be a bit tiring. I look forward to be able to compare the viewing experience with the motorised stand.
And I agree with you, the 11 is a very good mix from both a performance and design point of view. It's a shame they dropped the ball on such a successful design.
Fully agree. BV11 is really a timeless design.
Hiort wrote:
What a waste πŸ™‚
Send it my way 😁
It's yours for about £1500 😁 I'll be selling soon I think. I have to get rid of the BV12-65, too.
No worries ... the audible click is very soft (even with the volume turned up) ... and unless you are sitting in a silent room, you probably would never notice ... but it is there.
I had WISA issues ... but the last firmware update helped massively ... but agree that co-exisitng with even smart mesh wifi hubs that channel hop is challenging.
Good luck!
Saw the TV today. Everything was perfect as expected.
The only thing puzzling me regards the service counters.
I downloaded them this morning before going to the dealer for comparison sake.
My TV (BV11-55):
counterTimeTotalOnMinutes = int,699539
counterTimeTotalStandbyMinutes = int,1321671
699539 minutes over 4 years amounts to an average of 7.9 hours of usage per day. Simply impossible. And we even spent 4 months away at some stage. On the other hand, if we imagine the number to be in seconds we get an equally inaccurate .13 hours per day which is almost 8 minutes, seems a bit low. But even assuming it's correct, doing the same conversion for Standby would give me an unreasonable number.
The TV I'm buying is even worse, with a figure of 1604827 for On and 510183 for standby. Which means 18 hours a day powered on, impossible as well.
My dealer's technician was not there today and the service manual does not provide any useful information, so I have no clue on how to interpret those numbers.
Not if the TV has been on display at a dealer? If they open the store and switch on the TVs they'll be displaying a picture for 8 hours each day every day they are open.
Not possible in my case. I went to pick it from the dealer the day after the courier delivered it from Denmark (packaging was sealed and brand new). But it's a fair point for the TV I'm buying as I didn't think to ask if it was a display model.
Every time I walk into a dealer, the TVs are all switched on blazing away for hours and hours. Even if you walk past and the shop is empty on a quiet Monday morning they’re all on. I could understand if it were peaktimr like a Saturday or Sunday or lunchtimes - you’d want to show off your wares but not at dead times of the week. Puts you off buying an exdemo.
If you add up the minutes, its about 3.8 years, plus perhaps your 4 months away, - seems about right dosent it ?
