Greetings -
I have a pair of beolab penta ii's that I am trying to "properly" connect to my beocenter 9000. The wire that I am currently using is a 2 prong DIN that plugs into the back of the beocenter. The other end of the wires is just bare wire that go into the black/red sockets under the speaker. It looks like there are other sockets to plug into on the bottom of the pentas, but i cant seem to locate the proper ones -- the socket on the bottom of the speaker is different then the 2 prong DIN. There is supposed to be a digital display on the penta speakers that communicates with the beocenter, but I need it wired properly for this to be visible.
Does anyone have any insight or advice?
Thank you for your help!!
