Connection of iPhone to Beocenter 9300
how do I connect my iPhone to a Beocenter 9300 to play music from the iPhone through my Beocenter?
Had a look in the archives without success, I assume it must have been discussed a few times?
Thanks Steve,
decent price to play the iPhone music via the Beocenter.
You can also go through the aux to a wireless streaming device or Bluetooth receiver.
Apple Airport Express or Google Chromecast Audio are good ways to get wireless music from the iPhone to the B&O system, as these both use wi-fi for the best wireless signal quality and range.  The same cable (as mentioned above) also works with both of these devices.
Kind regards, Steve.
Hallo Beiber39
/ Peter Pan
If you want to add remote control with your Beo4 or BL1000 add the Apple interface:
Thaks Silou!
I also use a Beo4 to PC controller from this site, this way I can have an old computer connected to my Beovision 8 TV and operate it from my Beo4 remote.
Apparently, even better than using the headphone jack on an iPhone, it would be better to use a 30-pin to USB & 3.5mm jack (for iPhones < iPhone 5) as source. Quality would be better, I still need to test it (cables ordered)
Like this : link
As from iPhone 5, you can use a lightning splitter : it splits into 3.5 mm jack (for AUX input) & lightning (for charging)
Like this : link
And then connect one of these to the Steve's well known cables.
Like this : link
Like this : link
I agree. The AirPort Express has a very good DAC (IMHO). You could also use something like the Beosound Core (which is what I have) and that way you can use either the B&O app or any other app from your iphone or Android phone.  Both need additional audio connectors to work...
The allows for Bluetooth if you need that and the AirPort Express does not.
